Hi Azeddien,
All 8 Kanalog ADCs convert every servo sample cycle (90us). There is also a low pass RC filter on the inputs (Tau = 100us) so this is probably your main limitation. Also the Kanalog outputs only update every servo sample period (so if you use an output directly from KFlop to control your mux you may save one sample time delay).
Kanalog JP12 exposes the 4 of the Raw ADC 0-3V inputs as pins IN0-IN3. If you are able to drive those pins directly with a low impedance source you can bypass the low pass filter. The input circuit is basically a 0.01uF load.
